on 17-12-2024 02:24 PM
What sort of speed are those who are using the SH Pro getting on 2.4 Ghz?
I am getting 130Mbps everywhere to my Pixel 8, in the house seems remarkably stable when I switch off the other two bands. (On 900 package).
I reinstated SH Plus for comparison and am getting around 110Mbps to my Pixel 8 switching off the 5Ghz band.
I would have expected much more than that given in theory 600Mbps is possible.
17-12-2024 02:40 PM - edited 17-12-2024 02:43 PM
Feature Details
| WiFi standard | WiFi 7 |
| Number of antennas | 8 |
| Wireless capability | Tri band 2.4GHz (4x4): 802.11b/g/n/ax/be |
Should be good to about 600 mb/s on a 4x4 and 300 mb/s on a 2x2.Hope it helps. Highly unlikely that there is a single mobile device out there that has a 4x4 antenna array built into it, that's for sure....
on 17-12-2024 04:55 PM
@Ewan15 Quick speed test 2.4Ghz band laptop and tested for you. Picture below, so your phone is doing not to bad.
Asus laptop to EE Smarthub+ on 2.4Ghz
