Smart Hub Plus - Detailed Manual
AlanD5
Hi
Can anyone tell me where I can find a copy of a detailed manual (ideally in PDF form) for the EE Smart Hub Plus ?
For the avoidance of doubt, I am not talking about the little yellow quick start guide supplied with the smart hub plus, or the similarly limited on-line equivalents.
Thanks in advance.
There isn't 1! Anyway EE keep changing its spec by updates & some of it is done thro' the EE app. You could look for reviews on the Net.
Any update on AlanD5's March 2024 request?
I am also looking for "a DETAILED manual (ideally in PDF form) for the EE Smart Hub Plus".
The LITTLE YELLOW QUICK START GUIDE supplied with the SMART HUB PLUS in October 2024 is VERY short on detail!
@Rod81 : An update on my May 2024 response: There ain't 1!
