on 23-11-2023 02:42 PM
I am considering switching to EE Broadband (Full Fibre 150) but before doing wanted to check the features of the Smart Hub Plus. I have spoken to EE but "the technical department can't answer your question" so hoping someone here can help.
Firstly, I believe EE do not allow users to change the DNS servers. Is that correct?
Is it possible to disable the DHCP server within the router?
By way of background I run PiHole / Unbound as a local ad blocking DNS server so want all devices on my network to use this. If I cannot change the DNS to point to my PiHole server then disabling the DHCP server (and running my own) will give me back this control - this is what I currently do with my BT Home Hub.
on 09-07-2024 02:42 PM
@DeltaCharlie62 : That's just the way it is with the SH+. I don't provide updates to routers. I'm just a user like you! You'll need to apply to CS with any suggestions you might have.
on 09-07-2024 05:14 PM
