Signal strength issues
Kerrymw61
I changed from. Talk talk to ee for my home broadband and calls I already have ee mobile phone contact due to it being cheaper I  have been having problems with my signal I barely have 1 bar I am very unhappy and no one seems to be able to help when I call can you help me please
Mustrum
Hi @Kerrymw61 which signal are you having issues with - mobile or Wi-Fi?
If Wi-Fi, which router do you have?
Having only 1 bar indicates your issue is with the WiFi within your home rather than your BB.
2. Try both a wired & wireless speedtest here http://www.thinkbroadband.com/speedtest.html . Click on the "Results Page" button at the bottom of the graph you first see and then copy to here just the "Link to this result:" link that you see below the next main graph.
