20-10-2025 09:00 PM
Hi I have a smart hub plus and my security cameras have disconnected after about 5-10 minutes and won’t reconnect unless I turn the cameras off and back on, then they disconnect again been running for 6 months ok but I did have a similar problem when I first got the hub which an engineer sorted by adjusting the hub settings. Sorry I don’t know what he altered but nothing has changed since he did it and the problem has started again.
Any help would be appreciated
20-10-2025 10:39 PM
Try setting up Compatible WiFi on the router under Advanced > Wireless Settings & connect your device to that.
20-10-2025 10:39 PM
