SH32B hub - which WiFi extender do I need?
Adt1990
I have the smart hub SH32B and would like to buy a WiFi extender to create mesh WiFi. Which EE smart extender model do I need? I have the SW10A and believe it is not compatible
The Smart WiFi Plus (SW30A) goes with the Smart Hub Plus (SH31B & SH32B).The Smart WiFi (2023) (SW10A)s you have are meant to be for the Smart Hub (2023) (SH20A).
See  Setting up Smart WiFi & Set up your Home Broadband EE Router
