20-02-2025 02:36 PM
Hi, Just switched over from an old BT Hub to the New EE one but can't get my heating gateway (Salus It500) connected to the internet. Have plugged it into a LAN port (as with BT hub) but it doesn't connect..........any ideas?
18-09-2025 08:09 AM
For everyone who is struggling with the Salus it500 internet thermostat the above answer is correct & is the only answer that works as it stops the intermittent conne tion to the salus server.The problem is due to the new routers being super fast which the Salus Server can not cope with so a workaround is needed to slow down the speed{to the Salus server only}
This is the answer I managed to get eventually from Salus
