Router tv problem
Terryone
Had a new router installed and now everyday I have to put network name and long password into my tv to watch YouTube etc did not happen with last router
Maestro
Maestro
@Terryone You do not say which hub you have, but if a new latest model, look to set up the compatible network and use wpa2 with the TV.
Connect your devices using Compatible WiFi | Broadband Help | EE
Maestro
Maestro
Smart hub7 plus
@Terryone As above setup and try the TV connected to the comp network setting.
