Router light green
Hezzadot
Hi there I just got fibre max installed this morning however the router is still showing a green light. I have restarted and reset it. Can anyone help as it says it should be aqua?
15 REPLIES 15
By "installed" do you mean someone came in & did some work?  Have you yet got a msg from EE that it is up & running? Not until then. It could be anytime up ti midnight.
Hi there, yes engineers were out this morning putting in the fibre cables and I also got an email from EE saying that my broadband is now live. It is working perfectly it just doesnt have the aqua light.
Hezzadot
Solid green light on router since upgrading
Mustrum
Which router do you have?
Is it plugged into the ONT?
What lites are on the ONT?
Have you spoken to the Broadband care team?
It’s white with a circle in the middle smart router. I don’t know what ONT means and yes I have spoken to broadband team
Mustrum
What is the router plugged into?
What did the care team say?
A white box with 3 green lights. They said it should go aqua within 24 hours but it’s working fine with green light
Mustrum
The white box is the ONT.
Leanne_T
Hi @Hezzadot
Thanks for coming here.
Are you able to connect to the router and access the internet?
Leanne 🙂
