Really slow smart hub plus
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
28-01-2025 06:33 PM
Hi, having a real problem with my smart hub plus.
Had multiple visits from openreach for over a month for them to say today that there is no problem from the line between cabinet and my property, they says the problems with the router. On my 2nd router now and both saying 0.2 mbps. Tried the router at a friend's property and it worked fine.
Going round in circles speaking to EE.
Any suggestions would be greatly appreciated
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
28-01-2025 06:55 PM
@Scottparnell22 Are you able to log into the router and show us the WAN status page and Technical log?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
28-01-2025 07:05 PM
Hi, thanks for the reply, I think that is it below. Thanks 😊
This is a list of your Hub settings and current statistics.
Product code:Hub
Serial number:+112133+2230015330
Firmware version:v0.44.00.04123-BT
Firmware updated:Mon Dec 16 14:24:09 2024
Board version:R01
GUI version:1.80 11_07_2023
DSL uptime:0 days,00 Hours37 Mins35 Secs
Data rate:20 Mbps / 79.999 Mbps
Maximum data rate:25.029 Mbps / 89.262 Mbps
Full Fibre (FTTP) Mode:Off
Noise margin:9.5 / 8.6
Line attenuation:3.2 / 6.8
Signal attenuation:3.2 / 6.9
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:5.5 MB Uploaded / 22.7 MB Downloaded
Broadband username:bthomehub@btbroadband.com
Public Wi-fi status:Activated
2.4 GHz wireless network name:EE-FNCXCZ
2.4 GHz wireless channel:Smart (Channel1)
5 GHz wireless network name:EE-FNCXCZ
5 GHz wireless channel:Smart (Channel36)
Wireless security:WPA2
Wireless mode:Mode 1
Firewall:On
MAC address:A8:A2:37:F0:EA:2B
Software variant:-
Boot loader:0.1.7-BT (Thu Nov 30 09:45:22 2017)
This is a quick overview of your Hub's status.
Connection status:
Connection type:
Fibre Broadband (VDSL)
Firmware version:
v0.44.00.04123-BT
Firmware updated:
16-Dec-2024
Serial number:
+112133+2230015330
Downstream sync speed:
79.999 Mbps
Upstream sync speed:
20 Mbps
Network uptime:
0 Days, 00 Hours 33 Minutes
System uptime:
0 Days, 00 Hours 41 Minutes
Activated
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
28-01-2025 07:11 PM
@Scottparnell22 thanks, it looks like you have a good connection and with max speeds to the router. The only concern I noticed with a quick look is DSL uptime:0 days,00 Hours37 Mins35 Secs - have you reset the router or something?
Also how are you testing the speeds?
Do you have another device and are you able to use a device via ethernet?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
28-01-2025 07:38 PM
Yes I did another factory's reset earlier so that's why.
I'm testing via fast.com and tried 3 phones and 2 tablets all saying 200kbps. Haven't got a ethernet port on my laptop so haven't tried that but I did wire it up to my tv and that didn't work either. 😩
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
28-01-2025 07:53 PM
@Scottparnell22 OK, just to be sure, you are connecting to EE-FNCXCZ and not EE WiFI?
Could you try https://www.speedtest.net/ and https://www.thinkbroadband.com/speedtest and see if there is a difference.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
28-01-2025 08:04 PM
Still low download via speedtest.net 😕
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
28-01-2025 08:15 PM
@Scottparnell22 that is very strange.
You don't have a VPN or anything else that might be slowing things down?
Have you got a PC or Laptop that you can open a CMD prompt and then type tracert bbc.co.uk or similar. and post the results.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
28-01-2025 08:39 PM
Sorry i dont know what you mean.
I've got the CMD prompt opened on my laptop, what do I do then?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
28-01-2025 08:43 PM
just type tracert bbc.xo.uk
It should then just return something like this:
Tracing route to bbc.co.uk [151.101.128.81]
over a maximum of 30 hops:
1 1 ms 1 ms <1 ms DSL-AX82U-4630 [192.168.x.x]
2 4 ms 4 ms 4 ms 172.16.14.38
3 * * * Request timed out.
4 8 ms 8 ms 9 ms 62.172.102.68
5 9 ms 8 ms 14 ms peer3-et3-0-6.redbus.ukcore.bt.net [62.172.103.155]
6 * * * Request timed out.
7 8 ms 8 ms 8 ms 151.101.128.81
Trace complete.
- New contract but old model router? in Broadband & Landline
- 2 x EE Home Phone Adapters, neither contect to hub. in Broadband & Landline
- EE doesn't get contact number right in Mobile Broadband
- Smart 5G Hub - No Upload Speed & Constant Connection Drop Off in Mobile Broadband
- EE smart hub plus wifi enhancer in Broadband & Landline
