on 18-08-2022 08:52 AM
Hi explorer
your speeds are good if I got anywhere near that I’d be happy. I get anything between 2.3Mbs and 8Mbs the problem has been going on for ages now I’m supposed to get between 15Mbs and 18Mbs 🤔🥴 I’ve had new router boxes cables, and still same problem. But as I say your speed seems really good according to your photos, hope you get to keep enjoying those 😊
but any problems ee do normally sort them out pretty quickly and customer service is good in my experience. Unfortunately my problem seems to lye with bt outside the home
on 18-08-2022 09:37 AM
Morning @Sazurby
Thanks for posting.
Have you reported this to our broadband tech team?
Thanks 🙂
on 18-08-2022 10:58 AM
@Sazruby : Welcome to EE's Home Broadband Forum.
