Re: Speed is shocking so slow
DAVEdave9
I've tried a couple of times today to Log onto my EMAIL won't work I've checked speed it was 0.5 or below
6 REPLIES 6
@DAVEdave9 : Welcome to EE's Home Broadband Forum.
DAVEdave9
Leanne_T
Hi @DAVEdave9
Could you let us know the information @XRaySpeX has asked for above?
Leanne 🙂
DAVEdave9
I'm an old age person don't know what else I can do still very low speed that's only what I saw from app on my phone. David
If you asking for to connecting a lead I do not have any David
No, I'm not asking you to connect any cables that are not already there. You can do it over WiFi if you like.
