Port fowarding on Hub Manager doesn't load
wils01
I can access the hub manager fine; its very slow like. Anyways, I'm trying to port forward on my PC but whenever I click on the tab it gets stuck loading (I am connected via ethernet cable directly in the smart hub). Any suggestions on how to fix it? Thanks.
Edit: I'm getting the error [CHOP3-800] when I access the homepage sometimes.
bobpullen
Cliched as it may sound, have you tried switching the hub off and back on again?
The GUI on this router is extremely slow but on mine it does load to tell you that Access Control is managed by the EE app.
Eeextra
I'm having the same problem, did you find a resolution to this?
