Port forwarding on EE Smart Hub?
Kenyona
Has anyone had success setting up Port forwarding on EE Smart Hub?
I need to recover remote access to a Loxone heating control system which worked absolutely fine on a BT Home Hub
Yes!
Which Smart Hub do you have (read label or post a pix)?
Show your Port Forwarding settings.
Maestro
Maestro
@Kenyona Did not think that that old hub had any issues with port fwd.!
I've successfully Port Forwarded on both old SH & current SH+.
@XRaySpeX Did it on the + for the daughter as uPnP was oops but never had anything else so cannot say!
@JimM11 : So why say "not on the newer hub" when you don't know? You often mislead & put off users by your untested assumptions & misconceptions 😞 .
