Port Forwarding
Karlikihetep
Hi all,
Sorry if the solution to this is really obvious but I’m struggling to get this sorted.
So I want to port forward my PS5. I’ve gone into the EE router setting, found the PS5 and clicked on static IP, then saved. Unfortunately, this setting doesn’t seem to be sticking, the IP isn’t changing but the option for static IP is just showing ‘no’ even when I’ve changed it to ‘yes’ and saved.
So the next issue when I try and set up the port forwarding I have the following settings that I need to enter:
TCP/UDP - 1935, 3074, 3478-3480
But when I go to port porting sections it asking for internal port details and external ports and I have no idea what to enter!
All thoughts and help will be greatly appreciated.
thanks
Which EE router? Just read it off the label.
Just make External port = Internal port.
It’s the EE smart router
