PS5 issues
TheWirralWhite
Valued Contributor
Valued Contributor
Have Smart Hub Pro and Smart WiFi Pro, the latter being upstairs and about 2m from my PS5.
I have it hardwired to the WiFi Pro with decent speed, have until this week used WiFi to connect as seem to be getting the lan cable disconnected error flashing up a lot.
Over last day or two , tried using WiFi but getting signal too weak error using auto or either bands to connect.
Having no issues with WiFi with any other device.
Any ideas?
Northerner
Hi @TheWirralWhite
Do you have a pro or non pro PS5.
I think this is a PS5 software issue becase I have noticed this message since the last upgrade with a pop up saying it is disconnected 🤔
If you have non pro PS5 change your WiFi settings to connect to 5GH only.
Tried the 5g option but getting weak wifi error as well , strange as every other device is OK.
It's a normal PS5, not slim or pro
This is NOT a Playstation issue. It is the SmartHub Pro firmware issue. It's well known and documented in the forums.
