Openreach installing FTTC when FTTP is available
gazmix_1973
Hi
I've not gotten round to updating my copper broadband for family health reasons but had Openreach email saying they coming round to update digital phone & putting me on core 67 which is FTTC even though full fibre is on my street. I will receive my smart hub plus & phone adaptor shortly.
They say i have a fortnight to change mind, not sure what that means as won't be going back to copper but just wondered if FTTC will still work ok after the switch off in January?  I guess they wouldn't be doing it if it didn't. i Should've just ordered FTTP but as said i haven't . I guess i'll get this done & upgrade after.. I didn't think if FF was available on my street they would do FTTC.
132 REPLIES 132
Maestro
Maestro
@gazmix_1973 Do you have a medical marker against you home Broadband, that can be a complete reason for NOT going FFTP as yet, FTTC will still be working in complete DV over copper for many moons to come, FTTP can be in two flavours exchange wise, Priority is one off those reason's but will require a specialist team to take care off it all with a medical marker against it!
The Copper to FF Full Fibre can be done later so do not worry about it, should be a FREE upgrade EE/OR wise, just takes planning and time to get it done.... Have a look at the BTW with your ADDRESS details filled in to look see, number and postcode is generally all that is required. If you post it up be sure to hide all your personal details....
BT Broadband
Once FF Full Fibre is installed THERE IS NO GOING back to copper, just will never happen at all....
@gazmix_1973 We have been all round the houses and dancing around this all before so PLEASE let's not be doing it all again with you!
They're just keeping you on the existing type of BB you already had but moving your landline to DV. It's only if you were a new cust ordering from EE that you can't have FTTC when FTTP is available.
You sure that email was from OR? It's not their product to decide you should be on the Core Fibre 67 plan. It's for EE to decide & instruct OR to do the necessay work.
gazmix_1973
@JimM11  No medical marker, i guess you mean the button round neck linked to landline. Yeh i know i have full fibre on street, they've all got it.
@XRaySpeX EE initially contacted me regarding digital home phone & that Openreach will be contacting me which they did & gave me a date which i accepted.
Currently i'm on full copper, very slow speeds but said it will rise to minimum of 67mbps. I called & person i talked to said after fttc is done i then have a fortnight to maybe update to faster package but also said i can upgrade anytime which i thought was contradictory.
@gazmix_1973 The DV upgrade is a pretty straight forward way going forward, just remove your old EE Hub, stick the new one on, let it do any FW updates and reboots etc, plug the landline into the back off the EE Hub they have sent you or use the DVA if getting that supplied, If you are still on the old EE System they may also be transferring you to the NEW system at the same time, so a double win regarding that.... Fibre 67 is still a good and relative speed, it's not that slow in most individual cases, i had FTTC at 40/10 Mb/s as just too far from the street box to get any faster, was NOT an issue unless the daughter decided to stream a 4K movie, then bandwidth was just not enough and the Daughter/Mother argument's took over, FF speed you need to settle on but do decide and cover what is best for the home, i settled on the FF500 which is limited by OR when needed to 200Mb/s as a download, trust me have seen it happen.
@JimM11 : "Core" is in the name of a plan for New EE BB, but not for legacy.
@gazmix_1973 : Regarding speeds: What does BT Wholesale Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number or you don't have one, use the Address Checker, not the Postcode Checker.
You say you are on "full copper". Do you mean you're on ADSL?
@XRaySpeX Well aware off the new naming, and @gazmix_1973 looked to be all legacy BB before he raised this all again.
gazmix_1973
@JimM11  yep it looks easy enough, they sending out an adapter as router will be upstairs.  New system, yes i assume so, i was initially mailing here to make sure i'm good with fttc after Jan which you say i am so that's good news. Shoul'dve just ordered FF before EE contacted but couldn't. Will do after but the 67-73 probably adequate for 1 extra device & a firestick. Just the windows updates take ages.
@JimM11 : Yes, but you said "If you are still on the old EE System they may also be transferring you to the NEW system at the same time" & I was strengthening "may be" to "are"
garybs29
Scholarly Contributor
@gazmix_1973 wrote:
Hi
Are you 100% sure it's not FULL fibre 67 core?
