21-10-2026 11:59 AM
I am trying to access my EE account. I cannot use a one time code because the phone signal is too weak. It can take hours to receive anything by text. There seems not to be an email alternative.
21-10-2026 12:03 PM - edited 21-10-2026 12:09 PM
@Burland Have you tried using wifi calling if your mobile permits that as a function? If you are using a windows PC then the phone link when setup does get the codes fairly well same time as the OTA when EE sends it mobile wise.
Also try may be better option.
