No Parental Controls after move to EE?
jezthomp1
After being with BT for years I recently upgraded and they put me over to EE.
Still have the BT Smart Hub 2 and one wifi extender connected.
Setup up the EE app and only recently realised that the parental controls dont do anything!
When viewing the EE app it seems to think I have a Smart Hub which I dont I still have the BT hub.
How can I get the Parental Controls working, or is there a live chat with EE I can talk to about it?
6 REPLIES 6
Northerner
Hi @jezthomp1
Can you access controls via your old app on your BT hub you're still using.
I don't think the EE app will connect to BT hardware.
Maestro
Maestro
@jezthomp1 As @Northerner has pointed out, try your MyBT app, see what it does, the EE app has a lot of problems and NO one is 100% sure what/if/or why it does/does not work with the BT Router, fact you even got it connected is good, but for sure you will have all kinds of function issues, you may even have problems now when BT shut down the account side there end but until you try know way of knowing....  Also no chat function so you have to call speak with someone if you need assistance.
EE will struggle with the product, so BT guides will be best, they are cross-training with each other hopefully EE CS direct you to someone who can help. EE CS details on link below, but not even sure what is working today 2nd Jan. Main link click to where you want to go.
Contact Us | Help & Support | EE
Thank you, they ended up sending me an EE hub and all works as it should now.
Thank you.
Leanne_T
Hi there @jezthomp1
Thanks for coming back and letting us know 🙂
Glad this is all working as it should with the replacement router.
All the best for 2025
Facing the same issue. Also sent me the EE hub but still can’t activate the parental controls. Don’t suppose you know which EE hub you got. I think mine is the 2023 one. Maybe yours is the newer one?
@JezM72 Link below to the EE hubs and features that you get.
