No Broadband Connection in Ashton NN7
Keith2005
Over the last 8 weeks the broadband is not working and total blackouts are becoming more frequent
Why is there no information being provided by EE as to how they are going to resolve this.
BB issues are rarely localised but specific to your own line.
If it is a neighbourhood issue, you could consult BT Service Status to see if any faults are being attended to in your local area.
I hope this helps I think I have what is
Advanced Settings >
System >
DSL Status =
SSIDs.
Eh? Your post contains no info.
Use the Camera icon above your text to upload an image file to here.
