20-11-2023 09:49 AM - edited 20-11-2023 09:50 AM
Hi. I swapped from BT to EE for braodband and landline last week, this was motivated entirely by the ability to turn my children's wifi on and off. I also have two ee mobile contracts for myself and one daughter.
The smart hub came, (New black hub with EE logo on the front) when I scanned the QR code for set up it took my straight to my ee utilities app, no broadband account registered. So I followed the paper set up instructions. I had been dreading the switch over as have had constant problems with BT wifi and my Sky mini Q box, but no, both my Sky boxes and 3 smart tv's did not need wifi re-installed, bizarre but fine. The wifi works brilliantly and everyone is happy. However, trawling through ee to find out how to access wifi controls I see the QR code should have taken me to the EE Home app.
After downloading the app it could not link to the hub, I followed all the help steps, no joy. After trawling this community I reinstalled the app. Still no joy and yes the hub has been re-started several times, wiped off devices, reinstalled. So I called EE. After several attempts my account was found, my iphone 14 is up to date, no vpn installed, the app does not work on any of our apple devices, so they concluded it must be because they are apple devices and not android. I pointed out this couldn't be possible or they would have had thousands of calls by now. I am now waiting for a call back but have 8 days left of my cooling off period before I am stuck with this for 24 months.
Any ideas gratefully received.
on 06-04-2024 09:17 PM
Tag see my last most 👍👍
on 16-04-2024 06:20 PM
I’m new also, and just like you..after upgrading the app, it now won’t show for either of my I phones…after working fine prior to update? I get that it’s new, but all this tech and wires everywhere…around and around looking for advice, I also left Bt as I was told I would have no issues…I also had issues with my mobile and pac, this has now fixed…the thing that I found most annoying, is getting help? I guess another three hour conversation, not really convinced Ee are any different to Bt as yet…sorry I could not suggest anything other than empathy and shared frustration
on 16-04-2024 07:46 PM
Hey @Jim177322,
please read my post on page 5 or 6 in regards to IOS and Android phones and hub updates.
are you IOS or Android?
have you checked the hub to see if it has been updated ?
details on how to do it is on my last post on page 5 or 6
on 16-04-2024 07:59 PM
@Eddy2760 : Not all of us have a page 5 or 6. I only have 2 pages. Better to id a specific post by its timestamp.
Do you mean https://community.ee.co.uk/t5/Broadband-Landline/New-23-Smart-hub-can-not-connect-to-ee-home-app/m-p... or the post following it?
on 17-04-2024 08:22 AM
I’m using my iPhone so my end it’s pages lol 😂
yeah that’s the one, 06-04-2024 09:12 PM 👌
on 08-06-2024 09:43 AM
I have the same issue with an android phone so deffo not due to you using IOS. Like you, set up was a breeze but can't get in to the router to utilise the settings.
on 08-06-2024 09:56 AM
Found the solution, I think. Go into the WiFi settings and click on advanced (Cog Icon on right of connection name for android) and you the have the option to manage router. It must be a similar procedure for IOS?
Good luck.
on 15-06-2024 01:55 PM
Exactly the same problem. Sold on the pretence that I’m able to shut off devices. And the home app doesn’t connect. Everything reset. iPhone connect to the router and mobile data turned off. Just in case. Speed test works so I know it’s connected. Yet when I say I’m connected, the app says I’m not and I’m now in a loop. The help section is useless.
has anyone got a solution yet?
on 15-06-2024 05:39 PM
@Spirituk1 New version was released.
on 15-06-2024 07:10 PM
When was it updated? As I’ve only just had a new unit installed and downloaded the latest app. How do I upgrade the router and or the app?
