07-12-2022 06:15 PM
My broadband speed is too low and need an engineer to fix this
07-12-2022 06:17 PM
My broadband speed is not fixed. I have reported this and got a wifi disc sent to my address been using the wifi disc but still having problems and need an EE engineer to correct this fault. Thank you.
07-12-2022 06:50 PM
Can you send an EE engineer to my address to fix my fault as I am having slow internet speed and after 35 seconds having no internet service at all? This must be a fault and only an EE engineer can fix this. Thank you. Reported this a while ago and just got a wifi disc sent to my address? This has not helped the issue and definitely need an EE engineer to come connect the internet to my house so I don’t have these problems anymore. Thank you.
07-12-2022 06:58 PM
@RonnieGroves You will have to call customer services about this. This is a public forum so if you don’t call nothing will be done about it.
07-12-2022 06:59 PM
I tried to call but could not get through just got christmas songs and put on hold. This is not resolving the issue.
07-12-2022 07:00 PM - edited 07-12-2022 07:06 PM
@RonnieGroves Your not the only one calling so you’ll have to be patient and wait till someone can get to you. It’ll not be resolved if you hang up the call.
Looking at your past posts you are also saying you are getting slow speeds over Wi-Fi the speeds of your internet are over a fixed line not Wi-Fi. So that’s Ethernet cable to a device.
07-12-2022 07:36 PM - edited 07-12-2022 07:44 PM
Is your BB connection speed below EE's Min. Guaranteed Speed? EE will only look into it if it were.
