17-04-2024 05:28 PM
Why won’t my app pair with my hub I have upgraded to ee from bt and it does t work correctly it’s a joke I need the WiFi controls due to having children
28-10-2024 12:10 PM
Took just little over two weeks but finally my app is showing smart hub pro
03-11-2024 07:33 AM
Same here. Everything works except this pairing issue. Tbh the whole migration from BT to EE was very niggly and hopefully this is the final bit.
03-11-2024 01:23 PM
Hi there @SABco5
Thanks for coming here 🙂
Which router are you using?
Do you get an error message in the app when trying to pair?
04-11-2024 05:46 PM
04-11-2024 05:51 PM
@SABco5 You can only use the MyBT app with the BT Smarthub2 router if that is what you have, and depending on what BT have done with your account, then what you can do and access on the router.
05-11-2024 07:22 PM
Hmmm, thanks for the reply but in the app on the page where it says "Are you at home right now", there's a picture of the BT router I have which suggests very much that I should be able to pair with it.
05-11-2024 07:26 PM
@SABco5 Your device connecting has to be in the same IP range, the system can/will know if range is wrong or you are trying to go through a double nat. Are you trying to connect via the MyBT app to the BT Smarthub2 router?
06-11-2024 04:58 PM
Hi, Ive no idea what a double nat is or if Im double natting 🙂 . I should think my set up is as simple as it gets, basic home network, one hub/router, a number of wireless devices and a couple of mobiles. Never messed around with ip addresses - I just let the router do its thing. So, nothing fancy. Tbh, I dont know what the app will let me do - its just somethign that should work but doesnt and that bugs me..
22-11-2024 11:34 AM
Have you tried using your web browser and entering http://192.168.1.254 ? It will take you directly to the Hub Manager's page itself?
22-11-2024 11:35 AM
Have you tried using your web browser and entering http://192.168.1.254? It will take you directly to the Hub's Hub Manager page.
