My EE Hub has now taken on BT Hub details - what is happening?
Nitonboy
Valued Contributor
Valued Contributor
Tonight my EE Smart Hub is not recognising itself and is masquerading as my (old) BT hub.
Have to put in its name & pw.
What is happening?
Maestro
Maestro
@Nitonboy You must have selected to do the easy transfer, that is what it does, takes the old name/ password and puts it on you EE Router.
Set up your EE Home Broadband Hub | Broadband help | EE
Reset button on the router, called factory reset. will put it to the OOB settings. Keep fiddling you better learn how to use the HELP above.
Nitonboy
Valued Contributor
Valued Contributor
Ok. I was 'fiddling' about. Can I revert back do you know?
@Nitonboy  You’ll have to factory reset it,  this will put it back to how you got it out of the box.    There is a small hole on the router it’s got reset next to it.  With it powered on push a pin in it and hold it there for around 30 seconds this will factory reset it.
