Missing RJ11 (ADSL CABLE) and Mirco Filter
TimothyM
HI all i am new here
 my service is due to go live tomorrow and i received my router but when opening the box i am missing RJ11 cable (grey cable) and mirco filter i have the red & yellow Ether cables thats it
any advice
@TimothyM Slightly older router but believe it has a telephone connection...Then phone will plug into the back of the router, you will see the phone socket on it, can take a little time for the phone to register and settle on the digital voice, all of your other socket's or extensions if you use them will become defunct. Any problems head back to the forum, hope your change over goes smooth, and if you do not have many devices to change over onto the new router. There is a quick way to do it, and can help if you need. Welcome to the forum. HTH
10 REPLIES 10
Maestro
Maestro
@TimothyM What package did you subscribe to for your broadband?
@JimM11 Fibre36
@TimothyM Essential fibre 36 or full fibre 36?
@JimM11  my bad sorry Essential fibre 36
@TimothyM If you already have broadband and a master socket/filter older socket, then cable and filter can be connected to the replacement router. It would appear that you have been sent the wrong box. Let me know what you have.
@JimM11  i have old master socket what you need the filter for thats not a problem i can use the old filters i have along with the old RJ11 cable
as they have sent me the wrong box it will not effect performance will it as in its not set up for full fibre is it ?
@TimothyM Everything is the same, apart from one does not have the filter and cable, there is nothing different regarding performance, and with you having the old master socket that is your slowest point anyway, newer master sockets do help to increase speed of broadband signal cable and filter should work fine. Also copying you the help link. Are you keeping landline as another question for you? Also let us know what you have received router wise, should be the new EE Superhub+. Link is below for you.
https://ee.co.uk/help/broadband/getting-started
@JimM11  i am also switch my phone line over to the new digital line
looks like i was send SmartHub  (SH20A) as  it states that on the box
