Low speed why am I only getting 25mpb and not the 40 I'm supposed to get !
Lilsey
Iwas promised 40 and today I'm getting 25 ? Plus my router turns itself off randomly. I've had numerous engineers and new router , the speed then goes back to correct speed . Then it drops again !
@Lilsey : Welcome to EE's Home Broadband Forum.
