Laptop not seeing EE Network
Profile closed
Not applicable
Dell Latitude E7240  cant connect to Smart Hub 2
W10 22H2 build 19045.4561  (all up to date)
Had Full Fibre installed ... and while other devices (2.4 & 5 Ghz) connected OK to new Router
The Dell does not show EE network in the network list - i.e .no SSID
It does show 4 networks of my neighbours
Connected by Ethernet to make wure W10 and Dell drivers up to date
Did a repair of Intel WiFi drivers to be sure - no change
Profile closed
Not applicable
I have a Fix ..... at last
It seems that INTEL knew about the SSID not being visible in WiFi6 and fixed it in driver   v18.33.17.1
However when they discontinued the AC-7260 product support they took driver package off-line  😠
Luckily I found a post on Intel forum, a guy who not only knew the problem the Driver required to fix it, and the package release v21.10.1    and he hosts all of the packages on his personal site.
Downloaded, installed & tested  - working fine (currently) with router set to WiFi 6
In case anybody else comes across the issue the link is here:
https://community.intel.com/t5/Wireless/Intel-Dual-Band-Wireless-AC-7260-Driver-Update/m-p/1571741#M...
25 REPLIES 25
I believe that's an old PC & probably has a lesser WiFi then the router.
I think you'll find the router is set to WiFi-6 and WPA3 by default. Your device mayn't cope with that. Change the router settings down to WiFi-5 and/or WPA2.
Maestro
Maestro
@Profile closed Think that model had a 5ghz/wireless N wi-fi4 module so good to about 300mb/s speeds, would expect that wpa2 mode will be more acceptable for the security mode, Switch of the 5Ghz temp if it struggles to connect, My dell 6250 been ok on wpa2 - personal and wifi6 performance so far. HTH
Profile closed
Not applicable
I tried setting to WiFi 6 compatibility mode - no difference
I tried setting to WiFi5  mode - no difference.
Also tried turning off 5G .... to force 2.4GHZ connection - no difference.
PC worked fine with the previous Router (BT Smart Hub2)
My Printer which is much older than the laptop connected fine.
Well, that's the WiFi mode out the way. What about the WPA2 security mode?
Profile closed
Not applicable
In Router settings it says  Security type:   WPA2-Personal
@Profile closed ? is there a switch on the side of the laptop to switch off wireless.
Profile closed
Not applicable
Yes .. and its on .... as is WiFi LED display on keypad
@Profile closed If you right click the network globe, open network & Internet settings, what is the type of nic in the laptop, something not liked between dell/EE possible to try a setting like use 2-4g only in nic properties. Likes the Ethernet ok but not the wireless correct?
Profile closed
Not applicable
I did right-click as asked selected  'Network & Internet'
If I then select Network connections it shows for WiFi :
Intel (R) Dual Band Wireless-AC 7260
Driver is 18.33.9.3   (which Intel advise is most recent)
