Just joined EE broadband
Sparkyb
I connected to EE broadband 7 days ago with an estimated speed of 53-73 mbps guaranteed 46.5 mbps. While I know that in the first 10 days its gonna be unstable and speed variable, after 7 days to be stable at 3.7 mbps - same as its been the entire time - seems like its not right. Anyone seen this before?
The 10 days settling down period is an urban myth!
Mustrum
@Sparkyb   that sounds like you have a fault, have you recently moved from another supplier? If so what speeds did you have with them?
The 10 day settling down period is for ADSL but often gets used by ill-informed support teams on fibre circuits.
