Is EE FTTP dual or simplex !?
denede
Hello guys,
Maybe someone could help me because i'm intending on jumping to the 1.6Gbps package and i need to know if the actual fiber cable, more exactly the end of the cable is dual or single because i'm intending on having my own wifi7 router with spf+ support and i need to know which transceiver to purchase.(don't really want to use the RJ45 socket) - (I wont use their provided hub)
At the moment as a common sense person and because most widely available cables/transceivers are dual i purchased a 10GB dual spf+ transceiver in the 1310nm wavelength.
Best Regards,
denede
29 REPLIES 29
Maestro
Maestro
@denede Current Gpon OR info.
GPON uplink
• Wavelength: 1490 nm downstream, 1310 nm
upstream
• Line rate: 2.488 Gb/s downstream, 1.244 Gb/s
upstream
• SC/APC optical connector
• Compliant with ITU-T G.984.2 Amd1, Class B+
¬ +1 dBm to ~+5 dBm launch power, -28 dBm
sensitivity and -8 dBm overload
• Compliant with ITU-T G.984.2 Amd1, Class C+
(optional)
¬ +1 dBm to ~+5 dBm launch power, -30 dBm
• G.984.3-compliant dynamic bandwidth allocation
(DBA) by piggyback
• G.984.3-compliant Advanced Encryption Standard
(AES) in downstream
• G.984.3-compliant forward error correction (FEC)
in both directions
• 802.1p fixed mapping to queues
¬ Mapping of GPON Encapsulation Method (GEM)
ports into a transmission container (T-CONT)
¬ Remote software image download, activation
and reboot
denede
oh no.. i need a higher wavelength is seems to max it out and be future proof
but do you have actual 2 cables[socket] going inside or just 1?
AHarMan2
I didnt think you could bypass the ONT ?
ohh really? you cannot take the cable directly and put it into your own ?
if that's true, that's so bad...
@denede It's a single fibre cable!
AHarMan2
My understanding is the ONT has a serial number which is registered and used to activate the service ?
Happy to be wrong, but at a consumer level connection I don't think you can take the fibre straight to an spf router.
Maybe at a business level / business grade connection possibly.
So its a simplex instead of a duplex. Good to know
Ive seen other company that is also on the openreach network giving normal asus or tp-link routers..
That means, in theory, you could have any router and just plug in the cables if are compatible with the sockets
Activating the service i think it's done on the outside box of the building..
I might be wrong
Mustrum
@denede  What is it you are trying to do?
The customer interface from Openreach’s Fibre network is an RJ45 socket on the ONT (fibre modem) , it is a 2.5Gb interface. You cannot connect in any other way. EE like other ISP’S allow you to connect to this interface  with third part routers.
You cannot use your own ONT, at least not without a lot more technical knowledge and information you can expect to get on a public forum.
