Why is my third red light on my ont box flashing and ee app down
Papa26
46 REPLIES 46
virolo
My internet no work
@virolo : Is it the BB as a whole dropping or just the WiFi connections? Do Ethernet connected devices stay working? What colours are the light sequence when it happens?
BB issues are rarely widespread but specific to your own line.
If it is a neighbourhood issue, you could consult Check service in your area  to see if any faults are being attended to in your local area. You may also Report a Problem there.
Have you reported your problem with your BB to EE? They can't do anything about it until you do. Text HELP to 66033 to get EE to test the line & see what needs doing.
Which EE router & WiFi extenders, if any, do you have (read label or post a pix)? What is the name of the EE BB plan are you on including its speed?
HACKW04
Mine just went down also
Anyone else having problems? My router has completely **bleep** itself 😂
Tivzys
Same mines just gone off! 😡
Same here, I'm located in Yorkshire, so not sure if it's just local.
Mazzyb1
Mine too not happy at all
Gone down in Peterborough
HACKW04
I’m in Cheshire and down
