on 21-02-2023 07:46 PM
My internet connection seems to constantly keep going off and i refuse to pay for something that isn’t going to work so please could someone get in touch asap thanks
on 21-02-2023 08:15 PM
@Rossdunn7 no one on here has access to account information and has no idea who you are.
Ig you are having problems with your service, if you provide more details people on here may be able to help, or you can report a fault to the Broadband Care Team.
https://ee.co.uk/contact-ee/account-billing/broadband-landline
on 21-02-2023 08:43 PM
