Internet
Yvonnea1973
Why is my Internet slow speed reading of download 18Mbps upload 0Mbps something seriously wrong here
Kirigaya_Kazuto
Star Contributor
Star Contributor
Have you tried rebooting the router?
Ethernet or wifi?
Yes been rebooting since last night and still no speed when do a test
