Inaccuracy in Help Article "Using & Configuring a Third Party Router"
In Using & Configuring a Third Party Router > Step 4 is incorrect:
Fibre and Full Fibre
  • VLAN: Active (Full Fibre only)
  • VLAN ID (802.1q): 101 (Full Fibre only)
  • VLAN ID (802.1p): 101 (Full Fibre only)
The last 3 lines In Re VLAN are not valid for Full Fibre. The bracketed phrase should read "(partial Fibre (FTTC) only)". Also VLAN ID (802.1p) should be 0.
Lesley_W
Hi @XRaySpeX
Thanks for flagging.
It's been raised with the relevant team for correction, I appreciate you letting us know.
Lesley
Thanks.
