22-11-2025 11:47 AM
22-11-2025 12:52 PM
What is the "everything" you tried? You are using the EE App to do it?
23-11-2025 10:22 AM
I’ve tried it on the app with no joy , followed all the steps is says to do , restarts and resets , reinstalled app and still no joy , next step I think is to contact EE and see what they can do
23-11-2025 12:47 PM
Hi @Crusader606
What is happening when you try to connect to the WiFi controls?
Do you see any kind of error message?
Are you able to login to the app to view your broadband account details?
Michael
24-11-2025 12:45 PM
I get this every time I try , it used to work and then just stopped working
24-11-2025 03:45 PM
Are you currently using a VPN? If so switch this off and re-try.
