Hybrid Connect Stopped Working
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
09-01-2025 03:48 PM
My Hybrid Connect, which had been working perfectly since last October and always displaying good signal strangth (two 4g bars) has suddenly failed this morning with all three 4G bars flashing red. (which is how it should be according to the CS person I spoke to!). We did all the recommended problem determination stuff but no success so I am getting a new device tomorrow, I've had a few when I first joined EE but judging from other posts this may be the first of many more. Fingers crossed.
I noticed that the smart hub+ router had been restarted overnight, presumably to update firmware, and is now at r1.35.0-R-1138091-PROD-83002.
The sim in the EE Hybrid box by the way is the one from my BT Hybrid box as it was the only one that has ever worked.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
13-01-2025 08:32 PM
@JimM11FYI, had a call from TMC to explain that none of the devices I had been sent would ever work because the sims had not been triggered against my EE account following my migrate from BT. They will now delete any reference to Hybrid Connects from my account and I have to send the two I currently have, back.
I will receive a new one which will arrive preconfigured and, when I switch it on, ought to work but if not they will recognise and remotely activate. 🤞 This raises lots of questions about the processes but if it works.....
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
13-01-2025 08:49 PM - edited 13-01-2025 08:52 PM
@Malladee Hopefully it works, and they are not just blowing you off! When did you change from BT to EE! You just never know, when a unit is always in standby waiting to be called upon to be used, if that is the case, will be worth any new user testing the Hybrid, couple of day's after the BT - EE transition to make sure the Hybrid picks up and works. Keep us posted how it all goes!!!🙄
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
16-01-2025 04:55 PM
@JimM11New HC arrived and configured. Looked great with two solid 4G aqua bars at last (your device has a strong signal) so tested by disabling fibre. Both the bars turned solid white (your device is using mobile data to support your broadband).
That however was the end of the positives. Everything down - Not a single device could connect. I've got a call scheduled with TMC tomorrow pm so will see what they suggest. Changed from BT to EE last October by the way.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
18-01-2025 09:14 AM
EE tech support did not call to check new device as promised. I tested the new HC by removing the WAN cable from the router end (I have FTTP) and left this for at least 30 minutes - so while all looked good in terms of status lights, nothing worked. It also takes a while to all reconnect once WAN cable re-attached - presumably to ensure stable connection.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
18-01-2025 10:00 AM
@Malladee So then the EE Router indicated that the wan connection was gone and it's alleged that in 2-3 minutes, that the router indicates to the Hybrid that OK the Internet Broadband is down, Hybrid do your thing get online and indicate also that you are doing it, so now Router and Hybrid both together. The switch back has been reported 30 mins on a previous post and think you will be correct that it's just waiting to be sure no off/on/off/on with the router to be stable.
When all of this happened and you DO suggest it all looked good, YOUR devices that are all still attached to the EE Router because that is the control what were they showing you, got a connection but NO internet?
That's going to be hard to work out as there is 2 devices in the loop, would try them both together if you can get a 4g mobile signal on the Hybrid, attach an Ethernet cable between Router and Hybrid, repeat the wan test, try to eliminate, and see how that test goes. May rule out wi-fi issue between Router/Hybrid unit.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
05-05-2025 05:35 PM
Had exactly this problem last night. After several issues getting a Hybrid Connect that would actually connect to the 4G network, which was resolved with a new box supplied a few weeks ago (I migrated from BT to EE DEcember 2024), I though all was going to be good. Hybrid Connect is connected to Router via ethernet, 2bars for 4G signal. At about 2245hrs last night, the broadband failed - Router light went white, Hybrid Connect signal bars went white - all as it should be for "Resilience Mode" according to the documentation. BUT - nothing, not a single device, could get any internet service. The Hub Manager page for the Hybrid Connect shows no resilience event at all. The on,y event I can find logged that seems to be possibly related was at 22:43.nn where eth0 went down followed a few seconds later by eth0 up again. So, not only does the hub technical log not tell me anything useful about what was going on at the time, the kit failed to provide me with Resilience as expected.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
05-05-2025 06:10 PM
The Hybrid Connect Terms and Conditions quote a 2 to 3 minute delay time before the 4G service kicks in.
https://ee.co.uk/help/terms-and-conditions/broadband/ee-smart-hybrid-connect
Was this a prolonged loss of service or a 'blip' for a couple of minutes?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
05-05-2025 06:43 PM
@Mike_Chr Think it's an easy test check also, pull the wan connection and wait it out to see if anything goes, think there are some postings on the Forum with various waits for the connection time, and then when the wan is reconnected you can see when you hit the internet again, speed test would be a good option before/during/after/ and fully up!
- « Previous
- 1
- 2
- Next »
- Router continually flashing aqua in Broadband & Landline
- Always connected what a joke in Broadband & Landline
- Connection problems with broadband in Broadband & Landline
- Smart Hub Plus - Fibre installation in Broadband & Landline
- 5G Smart Hub lights no longer work (but Hub is working okay) in Mobile Broadband
