Hub flashing orange
PabloRed
Hi, my hub is flashing orange. I’ve checked all the cables. Steady green lights on BT connection box, POW,PON and LAN. Have powered hub down but still the same. Any ideas??
has come back on.
Peter_W
Thanks for the update here, @PabloRed.
I'm glad to hear that things came back up quickly!
If you ever face similar issues in the future, I'd recommend sending us a text with HELP to 66033.
This will run you through our fault checker, which gives you some troubleshooting steps, will check both the area and your line, and if needs be help you arrange a call back from one of our Guides or an engineer appointment.
Peter
Maestro
Maestro
@PabloRed You should check if there is an area wide service fault were you are!
Thanks Jim, I did look but it came back up after 30 mins.
Peter_W
Peter
