on 05-08-2024 06:29 PM
Got a Hp deskjet that I want to connect to the router via WiFi. Issue I have is I only have an android tablet not a laptop so the tablet only sees the WiFi I have the printer app on it but I need the printer to find the router and connect.
on 05-08-2024 06:53 PM
@billathome65 which router do you have and which printer?
Do they both have WPS buttons, if so just use that to find each other.
Not sure why you think you need a laptop though.
