17-07-2025 03:54 PM
Good Afternoon,
I need to disable IpV6 Settings on my Smart Hub, there is NO option to disable - Will I need to purchase a after market HUB to do this ?
17-07-2025 05:22 PM
Why do you need to?
17-07-2025 05:33 PM
Hi, I have been asked to by my workplace. Thank you
I just need to know how to do it or if I need to buy a personal router.
17-07-2025 05:57 PM
@Finfanero Why don't you just have the IT Team turn it off on the Equipment they gave you!
17-07-2025 06:04 PM
I have been requested to turn if off at the Router.
17-07-2025 06:07 PM - edited 17-07-2025 06:11 PM
@Finfanero Just do not see that, why would your IT want to cripple your network for there goal! Does your IT Dept control what you do! Is it the older white EE Smarthub that you have! All the others below show the latest in the link!
17-07-2025 06:13 PM
Doesn't make sense! Why should your employer restrict your use, & that of your family, of your home network nor have any right to? Anyway if you are accessing their site from it you'd surely be using a VPN.
17-07-2025 06:16 PM
I have this one SH32B
17-07-2025 06:17 PM
@Finfanero You can disable iPv6 with that hub, but i for sure am not going to tell you how to do it!
17-07-2025 06:23 PM
Try under Advanced > IPv6 > Config > Allocation mode to OFF.
