Full fibre speeds
Saviour008
 just had full fibre installed. 900mb Garenteed speed 700mbps
Is this speed correct ?
No, it's too slow.
Is that over WiFi or Ethernet?
This is wifi off my phone
S23 ultra when standing next to the router.
Are you able to try an Ethernet connected speedtest?
CraigR
Valued Contributor
Valued Contributor
Upload is good, download is well below what you should be getting, should be about double that, if not more. Try a different server for the speed test and if you can, a wired connection too.
garetc
Scholarly Contributor
Try using NPerf for speed tests, speedtest can get busy and report lower speeds than you're actually getting.
Also which hub did you get?
