Flashing green light
Nicko74
Hello. I have a hub that is connected  by landlines. It has been flashing green for a good few hours now. I have restarted the hub a few times and pressed the reset button. The green light comes on, flashes a few times then goes off. It then keeps going through this pattern.
Leanne_T
Hi there @Nicko74
Do you have a dial tone on your landline phone?
Could you try the test your broadband connection in the Fix An EE Broadband Connection Problem page to see if there are any problems found.
Speak soon 🙂
