Extending wifi signal from EE Smart Hub Plus (SH31B)
simonbath
I have just installed an EE Smart Plus Hub (SH31B). I'm getting good download speeds (almost 700mps) on devices in close proximity to the Hub, but I live in a 3-storey townhouse, and speeds on the middle and top floors are not great. Previously I had a BT hub with a round black BT booster and that improved the speeds on the upper floors.
Can I use something like a TP-Link RE550 Range Extender to boost the wifi from the EE hub, or is the only option to go for an EE product (the SW30A extender)?
11 REPLIES 11
Hi Bob,
I find myself in the same position as the OP. Is there a Smart Hub Extender equivalent alternative you would recommend from TP-Link or other reliable manufacturer. Would like to recreate the WIFI6 MESH experience without paying £240 over 2 years.
Thanks,
Matt
You can just buy the smart hub plus extenders on eBay. They sell for around £70.
Hope that helps
