23-01-2026 02:57 PM
Hi, I have new EE hub with the wifi extenders to get a good signal round my house. It's not a big house but when I was with BT they sent me them as I had spots that had poor signal. The question I have is I have a shed/ office down the garden with a CAT5 cable running down to it and I used to have a BT disc plugged in to it it from one I had in my kitchen via this cable. I don't know if it was supposed to work like this butu it did. However, it doesn't now work when I do the same with the new EE equipment. Is there a way to make this work with the gear I have? Thanks
23-01-2026 03:20 PM
Is the office on the same mains electricity circuit as the house? if so, you could use Powerline Adapters .
23-01-2026 03:28 PM
@Enduser New EE Smart Wireless Extender's in both places, one in the kitchen and one in the shed?
23-01-2026 04:51 PM
This is what I think I have done but it isn't working in the shed. Maybe an off and on again will be enough.
23-01-2026 04:51 PM
It is, I will look into this option if I can't get it to work. Thank you
23-01-2026 04:56 PM - edited 23-01-2026 05:05 PM
@Enduser This may help you also what is each off the lights on the units showing you>
Setting up WiFi Extenders | Broadband Help | EE
or
What the Lights on Your EE Smart Hub Mean | Broadband Help | EE
