14-12-2025 07:49 PM
Hi! We have had EE broadband fitted and the cable from the wall to router is short. We want to move the tv etc (attached to router) for a new room lay out. Can I buy a longer cable from the wall to the router and does switching (ie removing from wall so temporarily disconnecting router) cause any issues?
14-12-2025 08:19 PM - edited 14-12-2025 08:20 PM
@EmTyler Cat5e is good to 1Gb/s speed for a full 100Metres cable run, just buy what you need, whatever is in stock and a typical 10M = 33foot cable is around £7, if you get a cat higher it does not matter!
14-12-2025 07:51 PM
@EmTyler As long as you need, and switching it out is NOT a problem, Cat5e is all you require spec wise!
14-12-2025 07:56 PM
Thanks is cat5e a cable name? Sorry I’m not very tech aware!
14-12-2025 07:59 PM
@EmTyler Yes, you get Cat5e onwards the higher the number the higher the price, Amazon probably good to get just search Ethernet Cable and you will see various and then the length you need, ie 5M,10M 30M etc!
14-12-2025 08:02 PM
Oh amazing thank you. So just unplug from this box on the wall and use the new cable? I wasn’t sure if I needed to ask EE for an official cable .
14-12-2025 08:04 PM
@EmTyler You have the official EE one, does not get any longer than that for them, and yes just unplug, move your EE Router to where and plug them back in again!
14-12-2025 08:16 PM
Ah ok so they don’t do a longer one and I need to switch out for the recommended one above? Thanks - when you say the higher the number more expensive do i need a different one if we have a lot of streaming etc. I need it to be the same/better than the Ee one.
14-12-2025 08:24 PM
Thanks this sounds very simple. Cheers!
