19-09-2022 11:53 AM
Hi!
I moved my EE broadband to a new home and upgraded the speed to 100Mb/s a few weeks back. There was an engineer who came in and set up the boxes in my house.
Right now my Smart Hub must be connected to the port in a fairly big white box that's placed in a cupboard near the front entrance.
The red ethernet cable here is connected directly to my Smart Hub.
There are ethernet sockets in the walls in 2 rooms and one in said cupboard to which I tried connecting the Smart Hub but it doesn't work -- it say "Cable not plugged in" when I check its status connecting to the wifi.
What do I need to do in order to make these wall sockets work?
19-09-2022 04:15 PM
Yes, I would expect a house-wired Ethernet network to incorporate an unmanaged switch to make it work.
19-09-2022 09:16 PM
You don't need a switch. There are 2 ethernet ports on the socket under the ONT. Each port supplies one room only. If the port you've connected to doesn't supply a connection to your PC just plug in to the other port.
19-09-2022 10:37 PM
20-09-2022 12:24 PM
Then the devolper totally ignored Openreach guidelines. NB the telephone connection shown has now been ceased.
Image will show once approved by mods.
The full developer handbook is available HERE.
