Eero Pro 6E
RobBark
Anyone know if I can use the Eero Pro 6E directly into the ONT and authenticate with PPOE? Would like to take the SHplus out of the equation and just use the Eero Pro as the sole router.
Cheers
10 REPLIES 10
TWHH
Sorted it - needed to reconfigure the settings on the Eero while it was connected via Ethernet to the EE hub with it's (the EE Hub's) wifi turned off.
Annoyingly none of the guides mention that.
