EE broadband constantly high latency on ethernet connection
Bo-oF
The upload latency is constantly over 200, hovering around 220 - 280ms. This makes gaming literally impossible. Openreach have checked the line and have found no faults, EE technitian also found no faults within the service. We recieved a new router but the problem still persists. I have tried using all different ethernet cables (all Cat5e) for each connection. The service was working fine until about 4 weeks ago. EE have stated that there is nothing more they can do and offered a free cancellation. I have never experienced this sort of problem with any other provider. I have tried the network under loaded and unloaded situations and the results are the same, as well as only 1  device on the network (ethernet connected pc). The computer is mid end (3600x, 5700xt) so there are no issues with hardware. The issue still happens over WiFi on all my devices. The speeds are exactly as advertised (100D 20U), as well as the download ping being normal (for uk servers 16ms - 20ms).
30 REPLIES 30
Leanne_T
Hi there @Bo-oF
I am very sorry to hear this.
I would suggest getting back in touch with our broadband tech team to see if they can offer any other solution for this and help you further.
bobpullen
@Bo-oF - does the router you are using provide some indication of the amount of data uploaded/downloaded over a period of time? I'd be interested to know what that shows.
Is this only from a single device, or do all devices on the network exhibit the problem? How is your nework configured? Any additional access points/extenders, Powerline adapters etc. in play?
https://gyazo.com/c8086de987d28d794841ec7923219b82  It occurs on all devices on the network, through both 5ghz, 2.4ghz and ethernet (cat5e), changing the wifi channel or mode does not change anything. There are no extenders or access points, and the house does not have the capability to do power over ethernet.
This info will come out in the wash when you supply the router stats I requested.
Mustrum
@Bo-oF  how and where are you seeing the high latency?
Looking at the stats you have provided so far it appears you have downloaded 126Gb in just over 40 hours.
Have you got something streaming high resolution video or similar on another machine when you see the high latency?
The high latency occurs during gaming, any server causes my ping to hover 220 - 280, on uk and eu servers. It is specifically the upload latency, it can be shown through and Ookla speed test as well as a fast.com speed test (shown below). For e.g, Escape From Tarkov, a game I play has a ping limit of 200, when playing online i constantly get disconnected, even on eu / uk servers. While freinds are completely fine. CS2 is quite literally unplayable, constant freezes when loading players in, freezing when shooting and counter strafing. It is not a hardware issue.
https://gyazo.com/88539d5abe7825a5b4872b86b9858e25
https://gyazo.com/4dd1b80fcd6dd940fee5e2624e3ad07b
(Tests were NOT preformed at the same time)
Mustrum
@Bo-oF  that last link suggests congestion/high levels of traffic, guessing as you don't say taken when you were playing a game?
As a starter for ten, I would run a full anti virus scan, and a full Malwarebytes scan.
But as everything else is OK maybe you need more bandwidth for the games you play - might be worth asking any others you know if they have the same or higher speeds?
