EE broadband and sky Q
Kelz275
Hi I'm wondering if anyone can help me. I moved to EE about 4 months ago and ever since the apps on my sky Q box have been juddering. The only ones affected are youtube, YouTube kids and Spotify. I've tried everything suggested on the sky site and nothings worked so they think it's something to do with my broadband. Any suggestions would be great.
12 REPLIES 12
Kirigaya_Kazuto
Star Contributor
Star Contributor
What speed do you get on your EE broadband? What Ping as well?
Is your Sky box wired or wireless?
 just checked and this is what it came back with
Hi thank you for your reply I hope I've done this right. I'm unable to do a wired test as I don't have a laptop or PC.
Thanks. Would you run the speedtest over WiFi?
Are you on the Fibre Max 100 BB package?
Hi yes I'm on the fibre max 100 package I've just done the speed test this isnwhat I got
No, not that speedtest, but the 1 I requested.
Well, you are getting sync speeds, 159/29 Meg, appropriate to your Fibre Max 100 package & your speedtests are consistent with them. There is no obvious reason for your BB to be slowing down your access.
To try to get round this issue switch the DNS in the router away from EE's ones to Manual with 1 of these public DNS pairs:
OpenDNS   :	208.67.222.222 & 208.67.220.220
Google DNS:	8.8.8.8 & 8.8.4.4
Cloudflare DNS 1.1.1.1 & 1.0.0.1
