EE Smart Hybrid Connect vs EE Hybrid Connect
boltzy
I recently moved from BT broadband to EE broadband. With BT I had Halo 3 and a Hybrid Connect (EE badge on front). As part of move, I was send a new Smarthub Plus and Smart Wifi 'discs' to replace my old BT kit. However, I did not get a new Hybrid Connect. I noticed that on the EE website the 'Smart' Hybrid Connect looks different (matches the Smarthub Plus style).
Is there any real difference in my older EE Hybrid Connect and the new 'Smart' Hybrid Connect, for example a better aerial, better wifi spec, and/or can act as a 'mesh' endpoint? Should I insist they send me the 'Smart' Hybrid Connect?
10 REPLIES 10
Westkent
So if a service that you pay for goes down you can choose to be charged to keep it up and running at a slower speed.
well ain’t that a liberty 🤔
