EE Home app Speed Test
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
23-02-2023 07:07 AM
Hi folks,
I just had 500mb fibre installed a few days back and using the standard smart hub from EE, I was trying to perform a speed test in the EE Home app after I had setup my few devices , TV, Xbox, 2 iphoes and firestick. The speed test beings but then says us can't be don't as I maybe using a different router than the one EE supplied me? Only thing I have don't regards the router is change the network name and password from the one supplied with the router , openreach engineer set it all up when he performed the install on Monday. I know there are loads of speed tests out there, just would rather keep it all in the app.
Thanks , and appreciate any ideas / solutions
Simon
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
23-02-2023 11:57 AM
Hi @SimonD77
Thanks for coming here.
Have you tried removing and reinstalling the app and trying the test again?
Thanks 🙂
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
25-02-2023 01:04 PM
@SimonD77 I'm having the same problem as yourself. Using an ee router but getting the same message. Can do a speed test using the Ookla Speedtest App but like you would prefer to keep everything inside the ee app.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
25-02-2023 01:13 PM
@Leanne_T Hiya. I have tried removing the App and reinstalling but still have the same issue. I can use the app to test the connection which is fine but can't use it to test the speed.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
25-02-2023 02:33 PM
Hi @wgwright,
Our Broadband Support Team will be happy to look into this issue if you get in touch.
