EE Broadband Fibre
Trattobay
I am new to EE Broadband on a Fibre package which is rated at 36Mbps. The actual speed test is 20 Mbps against the average local speed for the area is 60 Mbps. Do I need to switch packages or could this be a technical issue?
Any suggestions are welcome.
Tratto
6 REPLIES 6
Jon_K
Former EE Employee
Hi @Trattobay
Is this with a wired connection or on WiFi?
One of our broadband experts in the community may be able to offer advice on how to improve speeds.
Jon
@Trattobay   How new to EE broadband are you ?     Have you received a email from EE stating what you can expect?   You get the email around 10-14 days after your broadband goes live
Hi Jon_K
I am currently using a Wi-Fi connection with a TP-Link AC2600 Dual Band Mesh Wi-Fi Range Extender, Wi-Fi Booster/Hotspot with 1 Gigabit Port, Dual-Core CPU next to my TV. My BT Broadband speed was about 36Mbps and we are due to get full fibre during the summer. The conduit is in place and all we need now is the cable.
The 20Mbps from EE is OK for my PC but too slow to run the TV.  Maybe I just have to be patient.
Thanks XRaySpeX,
I have printed out your reply and will now go on a voyage of discovery about connection issues.
As I replied to Jon_K we are due to get full fibre during the summer. The conduit is in place and all we need now is the cable. The 20Mbps from EE is OK for my PC but too slow to run the TV.  Maybe I just have to be patient.
BW Tratto
Chris B, about 12 weeks with EE so well bedded in an the 20Mbps is fairly constant.
BW Tratto
